Latest post 10-17-2007 6:50 PM by Razlaw. 3 replies.
Page 1 of 1 (4 items)
  • 10-17-2007 5:44 PM
    Serene coverage
    How well does the Serene work in the US with AT&T/Cingular?
    Thanks!
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 10-17-2007 6:11 PM In reply to
    Re: Serene coverage
    If you are in a major city or within a major metropolitan area, then it is fine.  However, I have been informed that if you go to the outlying areas, where the 850 band is more prevalent, because the 850 band is better for transmitting over longer distances, then this is problematic, since Serene is a tri-band, and not a quad band phone.  The same goes for the Serenata, which causes me to wonder why B&O didn't make the Serenata a quad band phone.
  • 10-17-2007 6:47 PM In reply to
    • Joe
    • Not Ranked
    • Joined on 10-03-2007
    • SoCal
    • Posts 74
    Re: Serene coverage
    waltoninn:
    You are right. The B&O dealers asked corporate many times for a quad band but they have not seemed to get the message. Part of the reason most of
    the dealers in the US refused the Serenata.
    Joe
    Its not just a product, its a way of life...
  • 10-17-2007 6:50 PM In reply to
    Re: Serene coverage
    Thanks for the input.That is exactly what I thought. My cell phone just died and I would really like to try the Serene if only it were quad band. I may give it a try and see if it works in areas I need to use it.
