1st March February 2012
Latest post 07-04-2008 3:34 AM by timhanna. 10 replies.
07-02-2008 4:06 PM
Weebyx
- Joined on 06-30-2008
- Denmark
- Posts 321
BV7-40 MKIII Weird Colors / Humming Noise
Hi, i am the "happy" owner of a BV7-40 MKIII television. When i first bought it, i noticed that it had a low frequency humming noice when the picture was very dark, i talked to my dealer, and he contacted B&O, and "they had never heard about people complaining about noise from BV7" before. I told them that i could not live with a tv that expensive making all that noise. It should be said that this noise is actually so high that i have to turn the volume up louder than i feel is normal. They told me that they are in the process of changing from HT to HS screens, and when the HS screen becomes available, they will exchange my HT with a HS panel. And so they did, this HS panel has the same noise, but i have discovered that if i disable "Adaptive Black" and turn the Contrast up 3 clicks, ths noise is "liveable". After they changed the Panel(not the entire tv) i have been noticing some funny colors. When there is a black/grey part of f.ex a black suit, it almost looks green. I didn't think more of it because it was very hard to tell when it should look like that, or when it was an error. Tonight however, my girlfriend was zapping, and fell over an old black/white movie, and OH MY GOD, this movie was black/green/white, i have never seen something look that terrible. When i turned the colors all the way down, the movie "colors" was black and white, but as soon as i turned the color back on, it became a green/white picture again. First thing tommorow i will call my dealer and hear what he has to say. Has any of you guys seen something simmilar ? Or even has the humming noice problem also ? /Weebyx
timhanna
- Joined on 11-28-2007
- London
- Posts 602
Re: BV7-40 MKIII Weird Colors / Humming Noise
My God, on a TV with the pricetag of a car, thats bad
Weebyx
- Denmark
- Posts 321
Excactly, i have talked to my dealer today, and B&O is taking the TV in for a checkup, they think that there might be som configuration that is wrong after the panel was exchanged. The humming noise is another issue, when i first got it, and noticed the humming, they ordered a replacement tv at once, the only problem was that the replacement also made the noise, the technitian who exchanged the panel, said that if the new panel also made the noise, then he could do no more. Apparently the noise is comming from the backlight converters on account of the powersaving feature i samsung panels, i have searched the net, and found others with samsung panels that has this problem, but they could turn off the powersave feature, and the the converters get more power and the noise stops. However i have not found this feature on the BV7 /Weebyx
timhanna
- London
- Posts 602
I dont know whats up with B&O, with my brand new BV7-32, 1 week old, keeps on crashing all the time, this is not really on. Have you had the TV for a long time, the replacement one?
Beolab
- Joined on 05-18-2007
- Sweden
- Posts 535
Weebyx: Hi, i am the "happy" owner of a BV7-40 MKIII television. When i first bought it, i noticed that it had a low frequency humming noice when the picture was very dark, i talked to my dealer, and he contacted B&O, and "they had never heard about people complaining about noise from BV7" before. I told them that i could not live with a tv that expensive making all that noise. It should be said that this noise is actually so high that i have to turn the volume up louder than i feel is normal. They told me that they are in the process of changing from HT to HS screens, and when the HS screen becomes available, they will exchange my HT with a HS panel. And so they did, this HS panel has the same noise, but i have discovered that if i disable "Adaptive Black" and turn the Contrast up 3 clicks, ths noise is "liveable". After they changed the Panel(not the entire tv) i have been noticing some funny colors. When there is a black/grey part of f.ex a black suit, it almost looks green. I didn't think more of it because it was very hard to tell when it should look like that, or when it was an error. Tonight however, my girlfriend was zapping, and fell over an old black/white movie, and OH MY GOD, this movie was black/green/white, i have never seen something look that terrible. When i turned the colors all the way down, the movie "colors" was black and white, but as soon as i turned the color back on, it became a green/white picture again. First thing tommorow i will call my dealer and hear what he has to say. Has any of you guys seen something simmilar ? Or even has the humming noice problem also ? /Weebyx
Can you tell me the full name on the HS panel ? Was the new panel the LTA400HS-LH2 or? Look into the "customer service menu" if you don't know: Menu + place the marker on options and then hit the red button + Go You find the panel name under "Screen Information" Because the HT and the HS panel got different color values in the Panel /PW ADJUST menu. The HT panel uses the double value on Green red, blue and white point for example. Thats why the colors are so funny. Your dealer service technician need to tune this values for the HS panel. And the "humming" noise should only be during warm up of the CCFL backlight (10min) then it should be quiet... Regards
a2bur
- Joined on 04-20-2007
- Posts 262
Obviously this shouldn't be , but your dealer should sort it out . My dealer couldn't be better , I have had a Bv7-40 for a couple of month and after a while it would shut down at 9 mins. past 6 & 12 every day , without hesitation they changed the set . Trouble was the new set did the same thing and the problem turned out to be a BeoMaster 7000 in the next room talking to a BeoLink 7000 [:'(] . I now have a minor speaker problem on a month old BS3 in a cinema set-up and again they have ordered a replacement . Richard
moxxey
- Joined on 04-14-2007
- South West, UK
- Posts 2,360
timhanna:I dont know whats up with B&O, with my brand new BV7-32, 1 week old, keeps on crashing all the time, this is not really on. Have you had the TV for a long time, the replacement one?
You don't want to know about my recent BV8-26 experience. Well, you probably do, but it's between me and B&O UK. Not good, not impressed. Every other experience has been fantastic, but my last and current has been my worst ever. Won't connect to BV7-40, when finally connected, they turn each other on/off, when controlling volume etc, BV6-26 was supplied grubby and with white paint drop on the back of the TV etc etc.
Weebyx
- Denmark
- Posts 321
The full panel name is LTA400HS-LH2J. When the technician changed the panel, he also changed the picture processor module, and updated the SW, but he never changed any values in the service menu. Maybe he thought that when changing the panel and updating the SW all was vell. The "humming" noise is actually at it's worst when the tv has been running for a while. But if i turn the contrast up, it goes away. /Weebyx
Weebyx
- Denmark
- Posts 321
Beolab: Weebyx: Hi, i am the "happy" owner of a BV7-40 MKIII television. When i first bought it, i noticed that it had a low frequency humming noice when the picture was very dark, i talked to my dealer, and he contacted B&O, and "they had never heard about people complaining about noise from BV7" before. I told them that i could not live with a tv that expensive making all that noise. It should be said that this noise is actually so high that i have to turn the volume up louder than i feel is normal. They told me that they are in the process of changing from HT to HS screens, and when the HS screen becomes available, they will exchange my HT with a HS panel. And so they did, this HS panel has the same noise, but i have discovered that if i disable "Adaptive Black" and turn the Contrast up 3 clicks, ths noise is "liveable". After they changed the Panel(not the entire tv) i have been noticing some funny colors. When there is a black/grey part of f.ex a black suit, it almost looks green. I didn't think more of it because it was very hard to tell when it should look like that, or when it was an error. Tonight however, my girlfriend was zapping, and fell over an old black/white movie, and OH MY GOD, this movie was black/green/white, i have never seen something look that terrible. When i turned the colors all the way down, the movie "colors" was black and white, but as soon as i turned the color back on, it became a green/white picture again. First thing tommorow i will call my dealer and hear what he has to say. Has any of you guys seen something simmilar ? Or even has the humming noice problem also ? /Weebyx
Weebyx
- Denmark
- Posts 321
timhanna: I dont know whats up with B&O, with my brand new BV7-32, 1 week old, keeps on crashing all the time, this is not really on. Have you had the TV for a long time, the replacement one?
About 2 months. /Weebyx
timhanna
- London
- Posts 602
moxxey: timhanna:I dont know whats up with B&O, with my brand new BV7-32, 1 week old, keeps on crashing all the time, this is not really on. Have you had the TV for a long time, the replacement one?
Shocking, really shocking, my BL7-4 Centre speaker has loads of dirty finger prints like patches that i cant, and wont get out... im hoping to hear what they have to offer me after this fiasco. Am I right in saying this guys, but does this only apply to LCD TVs. All my other equipment is perfect, no complaints at all! Even my Avant was thoroughly enjoyed
Page 1 of 1 (11 items)
