Latest post 10-07-2007 8:26 PM by Ignace. 2 replies.
Page 1 of 1 (3 items)
  • 10-06-2007 9:10 AM
    • sharif
    • Not Ranked
    • Joined on 10-05-2007
    • UK
    • Posts 21
    I need to make a lead to run a NON B&O Subwoofer
    I would like to know if anyone has made a lead to run a B&W PV1 sub using the PL from a BL6000.
    Can this be done?
    I dont mind if I have to switch the sub on manually , I just want the sound!!!
    Thanks in advance
    FOR EVERYTHING ELSE......THERES B&O
  • 10-07-2007 11:25 AM In reply to
    • ChrDH
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Denmark
    • Posts 493
    Re: I need to make a lead to run a NON B&O Subwoofer
    Just use a regular Din- RCA converter cable with all 4 Rca connectors. The 2 connectors that normally is carrying the "in" signal is carrying the R&L "out" signal from your Powerlink socket. I use this to get sound from my Ouverture to a Rega amp powering my B&W P5 Speakers.
    If you want the sub to turn on when using your B&O system, just get a TV-powersaving plug (have no idea of the english word, I use one of these to turn on the Rega amp, http://webshop.nesa.dk/projects/nesa/shop/cmsdoc.nsf/content/nesp73whg4?opendocument )
     br
    Chr.
    Beosound Ouverture, Beocenter 9000, Beovision MX6000, Beocord VX7000
  • 10-07-2007 8:26 PM In reply to
    • Ignace
    • Top 25 Contributor
    • Joined on 03-30-2007
    • Moderator - NL
    • Posts 2,749
    HI,
    the DIN-to-RCA connector i used with a Magnat active sub:
    The PV1 has auto sense on / stand by,
    so it switches on/off with the rest of your setup.
    Very nice sub by the way !
    500 W ICE power !
    Smile
