Latest post 10-07-2007 2:33 PM by jpb. 3 replies.
Page 1 of 1 (4 items)
  • 10-07-2007 8:01 AM
    • jpb
    • Not Ranked
    • Joined on 07-17-2007
    • Posts 10
    beosystem 3 & Projector
    Dear all,
    does anybody know whith which home cinema projectors the beosystem will work. I.e. control by beo4 etc.
    I guess there are more than the 2 sim2 and the 2 smansung. Does anybody know? Maybe some one has a list!?
    Thanks for your help,
    Yours, JP
  • 10-07-2007 8:23 AM In reply to
    • YannChris
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Larmor-Plage, France
    • Posts 276
    Re: beosystem 3 & Projector
    Hello!
    I can't help you about other products, but Sim2 projectors always have very good reviews in Home-Theater magazines... at least in France.
    Have a nice sunday,
    Yann.
    Ne pas s'en faire et boire frais!
    Mon install en images: cliquez sur mon profil, au dessus de mon avatar - Puis "My files" tout en bas.
    Pictures of my setup: click on my nickname, above my avatar. Then "my files" at the bottom of the page.
  • 10-07-2007 8:31 AM In reply to
  • 10-07-2007 2:33 PM In reply to
    • jpb
    • Not Ranked
    • Posts 10
    ....? what does that mean? No more than 4 projectors supported?
    I can't believe that!? - My dealer told me it will be possible to control my dvd, as there is a table
    that he will send to the beosystem that will allow it to control it. (even though it is not on the menue at  the moment)
    Any other experience?
    Thanks, jp
