Latest post 10-08-2007 10:38 PM by yachadm. 1 replies.
Page 1 of 1 (2 items)
  • 10-05-2007 6:34 PM
    Beomaster 4500 or BeoCenter 9000?
    I posted this in the other section but so far haven't received any advice. Maybe my fellow Americans can help? :)
    Here's the predicament; I currently have a Beomaster 4500 in very good condition. Not to mention I absolutely love the way it sounds. Here's the thing, I have an opportunity to get a Beocenter 9000 which is also supposedly in pretty good condition. "Pretty good" meaning it has a very small nick and the CD door needs a little push to close. It's also priced right, IMO.
    If I replaced the 4500 with the 9000 would I be "trading down"? I know the 9000 has loads more functions but what about the sound and overall quality? Also, what about this CD door issue? Is that a money pit or a small fix? I wouldn't mind spending a few bucks to rectify it. Someone with some experience please chime in.
  • 10-08-2007 10:38 PM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    Re: Beomaster 4500 or BeoCenter 9000?
    Quality wise, the 4500's mechanical design is way above the 9000.
    The 4500 is at its end-of-life for the electrolytic capacitors, which means you'll need to have them all replaced, if you want to enjoy continuing trouble-free operation, with the best sound possible.
    Just because the stereo "works", doesn't mean that all is OK.
    Martin Dillen sells capacitor kits.
    The BC9000's CD door issue is also a capacitor-related issue. Do the fix (and it is a simple fix - replace C2103 on the servo board of the BC9500 - it may be the same on the 9000), and it's good for another 7-10 years. In about another 5 years anyway, you'll need to replace ALL the electrolytic capacitors in the 9000 as well.
    Either make sure you're comfortable with this kind of work, or find a good electronician who will do the exact work you specify, and appreciates the difference between "a quick-fix repair at maximum profit", and "a full-restoration" so you don't have to visit him again for 10 years.
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
