hi jez,
this is turning out more complicated than i thought. following your message, i have done some tests at home. an aside before starting, my bc1 was delivered with a beo1 remote control, so i have been using the beo4 i got with my bc6 (which i am trying to connect...). all the link stuff is supposed to show up in the on-screen menus, but never has.
i used the beo4 as you explained to get to the option menu. first confusion, i want to share audio, but is a bc1 a video (v.opt) or audio (a.opt) product. i tried both, and when i set the option to 2, my bc1 blinked the little red light once. on the bc6, it did not respond to a.opt, but had the same one-blink response to v.opt. is this correct behavoir ?
thanks again,
scott
