I need help... :)
I have a Beovision 1 Link in my bedroom and am having problems with the Play Timer. It is not connected by link in any way and never has been as I never got around to doing so. Until now I have used the Play Timer to turn it off every evening and on again in the morning instead of an alarm clock, but suddently it stopped working.
After having turned off the main power in the house for some maintenance the Play Timer does not work. I have tried setting the clock, deleting all timer programmings and reentering them, turning timer on/off etc without effect. I have allso tried choosing all different beolink setup options to "tell the tv it's not in a link system"... :/
Any ideas how I can get it to work again, what the problem might be or if I can "completely reset the tv"?!?
