Latest post 03-19-2009 4:33 PM by Ehlerz. 2 replies.
Page 1 of 1 (3 items)
  • 03-19-2009 3:28 PM
    BL 3500 trouble
    Hi
    I just installed a Bl 3500 in my bathroom and linked it to my main room. I am having some trouble with the setup though. Is it posible to listen to a CD in main room while listening to TV audio on BL3500?. If i press TV in my bathroom, the mainroom switches to TV AND mainroom speakers are on?
    THEN if i press CD in my bathroom, i can listen to CD while the mainroom continues Previewing Tv...
    BS 3000 in mainroom, option 0
    BV 7-32 in mainroom, option 2
    BL 3500 bathroom, option 6
    BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
    Filed under:
  • 03-19-2009 4:20 PM In reply to
    • cjocc
    • Not Ranked
    • Joined on 09-07-2007
    • Sweden
    • Posts 39
    Re: BL 3500 trouble
    I might be out of line here, but is not this only possible if you have the CD in a BC2, which is capable to distribute parallell active sources to linked speakers in linked rooms....
    Just my 50cents. Sorry if I'm right  Sad
    /cjocc
    BC 2, MX7000, BeoPort, BLab 35000,BLab 3,BLab 8000,BeoC 6000, Beo4
  • 03-19-2009 4:33 PM In reply to
    Re: BL 3500 trouble
    That i dont know, but anyway. IF everything is turned off, turning on your linkspeaker on TV should not turn your main system and main speakers on , should it??
