1st March February 2012
Latest post 09-25-2007 10:56 AM by Dave. 19 replies.
09-21-2007 12:04 PM
Kellogg
- Joined on 09-21-2007
- Posts 52
Hi, Perhaps a silly question, but does anyone knows whether it is possible to re-program the 'TV' button on the BEO4 to act as an other 'button'? When most people now a days have STB's (for TVoIP, freeview, etc), then the TV button is not really used any longer. At least not in my setup  I am already using the DTV button for one STB and the V.MEM button for my HDR. Adding yet an STB would force my to use e.g. V.AUX which is only in the List. This annoys me, as if the TV button is re-programmed to act as V.AUX, then I would have all my source available with only one push on one button. Anyone knows if this is at all possible? Either as an official B&O solution or as an unofficial B&O solution? I know the obvious answer is: Get a BEO5 But it would be great if something could be done to the BEO4's I have as well. Thanks. -Lars.
PhilLondon
- Joined on 04-16-2007
- London
- Posts 2,545
Re: 'TV' button on the BEO4
In Beosystem3 (and I beleive on BS3 chassis Beovision), the internal DVB-T module is controlled with "TV" rather than DTV...
Peter
- Joined on 02-12-2007
- Posts 9,572
Interesting. How do you access the analogue tuner , or are the two simply accessed together?
Mico
- Joined on 05-06-2007
- Finland
- Posts 136
At least in my system TV starts the analogue tuner and DTV the digital one - both terrestrial and satellite channels.
PhilLondon
- London
- Posts 2,545
I do not have BS3, I read the manual and thought the you could mix DVB-T channels and analog channels under TV. I am probably wrong then.
The Stig - ver. 1.7
- Joined on 06-20-2007
- Posts 898
Thats not possible on BS3... I think you should tray and contact this danish company they make it possible to control any thing with beo4 would be an easy job for them.
Kellogg
- Posts 52
Thanks.
I will try to ask the guys at oneremote.dk if they have solution.
-Lars.
Daniel
- Joined on 04-17-2007
- Svinarp, Sweden
- Posts 1,284
Kellogg: Perhaps a silly question, but does anyone knows whether it is possible to re-program the 'TV' button on the BEO4 to act as an other 'button'?
We also have [TV] on A9 (key ring) and BL 2000. Would love to have them changed (or reprogrammed) to [DTV].
kallasr
- Joined on 04-19-2007
- Willich, NRW, Germany
- Posts 1,077
Why not this workaround: Put the external STB for example on v.tape2, delete all tv channels but one, name it STB, tell the system it is decoded and make v.tape2 a decoder connection. Choosing TV now gets you to your STB! Ralf
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
PhilLondon
- London
- Posts 2,545
But then you can't use the PUC...
nobby
- Joined on 04-21-2007
- Posts 539
Hmmm ... dont understand this ... or how it works ... can someone explain, it sounds damn useful. Neil
kallasr
- Posts 1,077
Ok, let's try again: using the "TV" button selects the only TV channel there is - the one named STB. (the name doesn't matter - I you a Dreambox so mine is called Dreambox). Since the TV thinks it is a channel that needs a decoder automatically the decoder scart plug is selected, in this case V.TAPE2. About the PUC I am not sure, I have never seen the set-up/settings. I admit I use the Dreambox remote control for the STB. But at least no list stuff for selecting the Box. Maybe this can help... Ralf
nobby
- Posts 539
Hmm ... interesting ... I will go home now and try this!
Chrisreunion
- Joined on 07-01-2007
- Reunion Island
- Posts 677
I never tried to control a STB through the TV channels, but on my BeoCenter 1, I programmed both SCARTS as decoders, and stored 2 TV channels for each of the decoders. This way, when I choose TV 1, with decoder 1activated, it shows "BEOCORD" (for my non B&O VCR) , and when selecting TV2, with the decoder nr2 activated, it shows "BEOMEDIA" (for the PC that's connected). Same for my BV3: I only stored one TV channel, that I set up as a program needing a decoder, connected my PC Y/C + audio output to the DECODER SCART at the back of BV3, and now have the PC display on BV3 just by pressing "TV"! Since BV3 has no "PC" source control, it is quite practical to do so.
Whether you can remote control the STB is another question! I don't use any STB...
Reunion Island is greeting you!
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
I find this subject fascinating. I haven't used my TV button for ages. Neil, will you let us know how you go on? Andy T.
nobby
- Posts 539
Hmmm ... well, call me stupid ... but i forgot how to "delete" all the existing channels ... I need to dig out the instructions or can someone remind me how to do this on the later software MX4000 etc. (say Improved Text version or newer) ? Neil
Dave
- Brisbane, Australia
- Posts 2,328
When editing TV list, press menu when a channel is highlighted, and it comes up with "del?"!
Dave
- Posts 2,328
Our BV3 isn't falling for this trick. How do you do it! I deleted all channels but one and named it DTV, and the STB is connected via that sat scart. Does it need to be set a certain way? Help!
PhilLondon
- London
- Posts 2,545
You've got to go to the sources and say that the scart where the set top box is connected is a DECODER. Then you edit the "DTV" channel and say that it needs a decoder. When you call that channel, it will send the encrypted signal to the decoder via the scart, and get the decrypted signal back from the scart and display it. In this specific case, as the box is not a decoder, the input signal is ignored. The downside is that you can't use a set-top box controller anymore. It works on an AVANT and an MX, but I do not know if it works with newer set. I do not know if my BV7 has this DECODER feature. p.
Dave
- Posts 2,328
Ok ok! Eureka, thanks for the help that's neat! Too bad can't use the stb controller with it, because it makes more sense to turn on the telly with the TV button.
Page 1 of 1 (20 items)
