There are 5 decks in this series, though the 6002 and TX are really only similar in looks.
The 6006 and 8000 are to all intents identical except for finish - the 6006 is black - and the cartridge fitted. The 6006 has a 20EN as standard where the 8000 uses a 20CL. Both are tangential tracking and tangential drive turntables. The latter means that the platter is moved using a rather clever induction motor so that there are no belts or gears involved. Very accurate speed control and wow and flutter too low to measure compared to a normal deck.
These decks were replaced by the 8002, which was similar but used the newer cartridges and had a redesigned platter with lower ribs. Otherwise much the same though the later 8000s and the 8002 had a metal tacho disc which is an avantage these days!
At the same time as the introduction of the 8002, the 6002 and TX were wheeled out. These look much the same but are in fact belt drive decks and are much simpler in construction. The 6002 has one way datalink but the TX has none. They are actually rather good sounding decks and not dissimilar to a 4002 in some ways. Better in my view than the later tangentials though the specs would say otherwise. Just shows to listen to the deck and not the specs!!
