Latest post 12-03-2007 9:34 AM by kevinoils. 6 replies.
Page 1 of 1 (7 items)
  • 11-22-2007 8:30 AM
    • bwaje
    • Not Ranked
    • Joined on 11-22-2007
    • Paris - France
    • Posts 38
    Beogram 1200
    Hello,
    this is my first post here, as I am a new b&o owner ; however, I have used my parents' beovision 1001 since 1974;
    I recently bought two beogram 1200 turntables (one doesn't switch on) and discovered that they have different belts ...!
    One has a round belt and the second is a flat and used; so what is the good one ?
    And is there a fuse preventing the turntable to be switched on ?
    bwaje
    b&otien
    Filed under:
  • 11-23-2007 6:04 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: Beogram 1200
    Martin (Dillen) is probably the man to speak to here!
    I'm sure he wouldn't mind if you sent him a PM !
    Lee
    Smile
    PS - Welcome to BeoWorld !
  • 11-24-2007 11:25 AM In reply to
    • bwaje
    • Not Ranked
    • Paris - France
    • Posts 38
    Re: Beogram 1200
    In the end, I'm almost certain that the good belt is the round one, but I need to change it to my 2nd beogram, do you know how to do it ?
    How do I remove the platter ?
    b&otien
  • 11-29-2007 12:29 PM In reply to
    • bwaje
    • Not Ranked
    • Paris - France
    • Posts 38
    Re: Beogram 1200
    so, anyone knowing about removing the platter please ?
    b&otien
  • 11-29-2007 1:00 PM In reply to
    • Dillen
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beogram 1200
    To dismount the platter;
    Push up the center tap, grab it and pull straight up (there's a spring underneath).
    This will reveal three screws, undo these and the platter is lose.
    The round belt is the correct one.
  • 12-03-2007 7:51 AM In reply to
    • bwaje
    • Not Ranked
    • Paris - France
    • Posts 38
    Re: Beogram 1200
    Thanks Martin, it was easy, but the center tap is very fragile, and can bend on mounting
    b&otien
  • 12-03-2007 9:34 AM In reply to
    Re: Beogram 1200
    Hi there are you going to retore the beogram 1200s as I have 1200 and 1202, I am aiming to get them back to as good as as soon as I have the chance and knowledge so this post could be useful.
    Kev
