Borjal84:Apple 30" monitor is much better than BC6(more resolution and has 2 DVI), and the price is lower.
With all due respect, Borjal84, I don't agree. I have Apple monitors (I'm an Apple addict) and I have been considering the BeoVision 8 as a computer monitor, as I like the shape and image.
My 50" plasma has the same resolutions as the BC6 and BC8, and I'm typing this using a bluetooth keyboard at a distance of four meters, using that screen as a monitor.
I've tested the BV8 resolution, and it is absolutely satisfactory for me on the 26", and I have studied it on the BC6 as well. I'm going with the BV8 because it fits with the design of the rest of my office - and I kind of like having something that's different from the now ubiquitous Apple monitors used everywhere in my branch of business.
As to the top resolution on the Cinema Display from Apple, I'd say that comes in useful when you are doing close-in graphics work, photography, graphics design, etc. Otherwise it is an unnecessarily high resolution, and sometimes even tiring to the eye. And if you want to use the monitor to watch movies, etc., using your computer as source, then you'll use less processing power and therefore hear the fan less with the standard PC resolution -- worth thinking about.
