Hi again,
Another beginner question. Is it possible to daisy-chain masterlink devices? For example, since I'm not allowed to drill a hole through my walls, I'll need to run a masterlink cable out of my living room, through my hallway, and into my bedroom for my BL 3500. I thought that since the cable has to go that way anyway, I could dig up a BL 2000 for the hall.
The question is: can I run a cable to the 2000 and then another one away from the 2000 to my 3500?
