Latest post 09-18-2007 5:44 PM by 9 LEE. 1 replies.
Page 1 of 1 (2 items)
  • 09-18-2007 4:51 PM
    • beowhit
    • Not Ranked
    • Joined on 04-17-2007
    • Brompton, Kent
    • Posts 26
    BV3-DVD1 issues
    I've just set up the B&O in my new living room and have a couple of issues with the BV3-DVD1set up. Firstly the auto format doesn't seem to work on the TV channels except for films on Channel 4 - although I've been told this is a signal fault and not a fault of the TV, it's just really annoying. Secondly after playing a DVD for about 20 minutes the picture develpes a green hue - all the whites are a light green while other colours seem normal. The TV is 2.5 years old and has recently had a chassis change and all the cables seem secure. It works normally whilst watching TV so am I right in assuming its a DVD1 fault? I will be contacting my dealer in the morning who is very helpful, just wondered if anybody has had similar problems.
    Mark
  • 09-18-2007 5:44 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: BV3-DVD1 issues
    It does sound a bit DVD1-ish to me..
    Just for the sake of it, try swapping the scart lead.  At least that will eliminate it!
    Lee
