Latest post 09-10-2007 3:04 PM by Keith Saunders. 2 replies.
Page 1 of 1 (3 items)
  • 09-09-2007 1:32 PM
    • grQmma
    • Not Ranked
    • Joined on 09-09-2007
    • Posts 2
    Defect LE6000
    Hey!
    A few days ago i bought a used B&O LE6000 TV
    After a few days the picture suddently broke. or it went in to be a straight line through the center of the screen aprox. 20 pixel high.
    Does any one haw a clue what the problem could be?
    Best regards
    Michael
  • 09-10-2007 6:17 AM In reply to
    Re: Defect LE6000
    could be the scan panel that has gone faulty.
  • 09-10-2007 3:04 PM In reply to
    Re: Defect LE6000
    Your problem is called field collapse and is quite common in older TV's.
    It occurs when the vertical oscillator or the driver from it to the scanning coils fails.
    For a good TV technician this would be a fairly straight forward fault to fix.
    Regards Keith....
