Latest post 09-09-2007 3:27 PM by Peter. 4 replies.
Page 1 of 1 (5 items)
  • 09-05-2007 12:05 PM
    HELP NEEDED BV7
    I have a BV7-40 6mths old, problem is i am getting what looks like ghosting similar to cordless phones used to create on the picture, not all the time and mostly when changing channels on the sky box, the lines are diagnol and are grey coloured overlayed faintly on the screen for approx 15 seconds.
    Has anyone any ideas what might cause this
    JOn
  • 09-09-2007 12:53 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: HELP NEEDED BV7
    Anyone any ideas on this?
    Lee
    Indifferent
  • 09-09-2007 12:58 PM In reply to
    Re: HELP NEEDED BV7
    Is the Sky box earthed? We have an earth put into the aerial loop simply to avoid interference. Worth a try.
  • 09-09-2007 2:35 PM In reply to
    Re: HELP NEEDED BV7
    Peter you beat me to the reply, I spoke to B&O and they advised it could be a earth issue, so i took apart the sky box and earthed it up, and guess  what it has cured it.
    Jon
  • 09-09-2007 3:27 PM In reply to
    Re: HELP NEEDED BV7
    Glad to hear it!
