Latest post 10-08-2007 8:33 AM by shuni. 4 replies.
Page 1 of 1 (5 items)
  • 10-08-2007 3:36 AM
    • shuni
    • Not Ranked
    • Joined on 05-09-2007
    • Posts 4
    cable setup for cona subwoofer?
    I am buying a cona subwoofer-I've seen the wiring diagram on this website but it is still unclear to me-
    How do I connect cables to it? Are they 2 din plugs or 3.5mm, or just bare wire?
    and if they are wire only, what grade of wire is recomended? where to purchase it in the UK?
    thankyou so much, guys
  • 10-08-2007 4:37 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: cable setup for cona subwoofer?
    Hi shuni,
                 the connections are very simple. There are Left & Right cable inputs (from your amp) & left & Right outputs to your speakers. All connections are screw clamp onto bare wire.
    Chris.
  • 10-08-2007 4:39 AM In reply to
    • Christian
    • Top 100 Contributor
    • Joined on 04-16-2007
    • Copenhagen, Denmark
    • Posts 626
    They are just bare wire. The connectors are of the screw type.
    Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
    Addicted? Oh no.... ;)
  • 10-08-2007 5:35 AM In reply to
    I have one of these and just thought to add that you'll need two DIN plugs to connect to your Beomaster from the input side, and two DIN socket plugs to connect up to your B&O speakers from the Cona's output (hope this makes sense).
  • 10-08-2007 8:33 AM In reply to
    • shuni
    • Not Ranked
    • Posts 4
    thankyou so much for your replies, now i know what to do. cheers
