Latest post 09-01-2007 3:56 PM by Kokane81. 5 replies.
Page 1 of 1 (6 items)
  • 08-31-2007 1:50 PM
    non b&o tv + beocenter 2
    Is it possible to connect a BC2-dvd to a non b&o tv (loewe) and use  2 beolabs 9 as speakers for the tv?
  • 08-31-2007 5:05 PM In reply to
    Re: non b&o tv + beocenter 2
    yep you can.
    dead easy to do and vey commonly done.
    just needs scart cable from beocenter2 socket box to the T.v.
    speaker cable goes back to the socket box as well as fm/ dab aerial.
    you will need a beo4 if you want to control it remotely.
  • 08-31-2007 5:57 PM In reply to
    Yes it's possible. Connect TV to BC2's AUX in with a RCA cable, then when you set BC2 to AUX it plays the TV's sound.
    "NOTE"
    The DVD function in BC2 don't work very well with non B&O TV's, you are not able to control DVD functions with Beo4. only  with the buttons on BC2. Erm
  • 09-01-2007 2:25 PM In reply to
    trust me the dvd player will work with a beo4 you don't need to only use the buttons on the bc2.
  • 09-01-2007 3:37 PM In reply to
    Kokane81:
    The DVD function in BC2 is controlled by the TV via the scart cable with DATA link. but maybe if it's in option 2 it's possible?? Embarrassed
  • 09-01-2007 3:56 PM In reply to
    This will work in option 1 or 2.
    If you find that your speakers switch off when changing from A.Aux to DVD you'll need to go into the DVD menu on screen and change output to scart and powerlink rather then just scart. this will stop this from happening.
    by the way you'll need to use a.aux function to get the sound from the t.v to come through.
    you might need to add this to the beo4 remote and you might need to also add this to the bc2 display so you can find the function when you press list on the bc2 front panel
