Latest post 09-01-2007 10:28 AM by Emmanuel92. 6 replies.
Page 1 of 1 (7 items)
  • 09-01-2007 4:52 AM
    • matheyl
    • Top 500 Contributor
    • Joined on 04-18-2007
    • French Alps
    • Posts 228
    Transport AV 9000
    B&onjour à tous,
    Savez-vous s'il est facile, ou d'abord possible, de désolidariser la télévision proprement dite de son socle sur un AV9000, pour faciliter son transport?
    Je n'ai rien vu concernant ce point dans la section user et service manual...merci d'avance!
    B&on week end,
    Laurent.
    Avant 28 DVD, BC2, 2300, BL2500, 8000, to name a few...
    Filed under:
  • 09-01-2007 6:00 AM In reply to
    Re: Transport AV 9000
    Bonjour Laurent,
    Je ne sais pas si c'est possible, mais j'ai entendu et lu plusieurs fois que le pied est très fragile et peut casser lors des transports, donc faire très attention au pied !
    Bon transport de cette merveille.
    Quoi de mieux qu'un BeoLab 2 ? 2 BeoLab 2 !
  • 09-01-2007 6:24 AM In reply to
    If my school boy French is to be believed (!), you want to separate the AV9000 to make it easier to transport. This is certainly possible as the monitor section is held onto the base by two large clips. I'll see if I can find the actual assembly manual - however this is definitely a task suited to two people!! It is heavy!!
  • 09-01-2007 6:49 AM In reply to
    • matheyl
    • French Alps
    • Posts 228
    Yep, Peter, your French understanding skills are ok, for that topic, at least Wink
    Many thanks in avance,
    Cheers, Laurent.
  • 09-01-2007 7:38 AM In reply to
    I have put the manual on which has the assembly, and disassembly, instructions!
  • 09-01-2007 10:10 AM In reply to
    • matheyl
    • French Alps
    • Posts 228
    thanks a lot.
    Have a good weekend,
    Laurent.
  • 09-01-2007 10:28 AM In reply to
    Peter:
    You're a star Peter Cool
