Hi
Is there a 'correct' way to position two bs4000 speakers?
ie should the speaker side be on the outside, or should it be on the inside.
My dealer positioned the speakers on the outside. In fact does it make any difference and has anyone tried the other way round?
From an aesthetic view I think I like mine as they are, but from acoustic position is there any difference?
Cheers
Brian
