Latest post 08-27-2007 8:16 AM by 355f. 6 replies.
Page 1 of 1 (7 items)
  • 08-26-2007 5:55 PM
    • Tom
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Luxembourg
    • Posts 3,175
    Hmm [^o)] TV picture adjustments
    Lately, I am changing the picture settings on my BV7 all the time, but I am never happy with the result. Most of the time, I think that the image is to dark, but if I add more brightness, it is too bright for some programms, if I add more colour add take away brightness, I dont like the colours...
    Is there any trick or a specific DVD I can use to set it up in the right way. I know that somehow it is a question of taste, but there must be a reference that could guide me?!
    Music washes away from the soul the dust of everyday life. - Berthold Auerbach
  • 08-26-2007 9:18 PM In reply to
    • Beolab
    • Top 150 Contributor
    • Joined on 05-18-2007
    • Sweden
    • Posts 535
    Re: TV picture adjustments
    You can try the DVE Digital Video Essentials disc  http://www.videoessentials.com/index.php (DVD/HDTV-calibrator for Pro users )
     Plus you can increase the master contrast in the service menu. (but on your own risk)
    Best regards
    BL8000 MkII Black
  • 08-27-2007 3:35 AM In reply to
    Monster has also an ISF calabration DVD
    http://www.monstercable.com/news/2005-12_HDTVwizard.asp
  • 08-27-2007 3:36 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    I can mail you a test DVD. Just 5 MB. But good enough. You need a DVD burner.
    Let me know via PM.
    Regards
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 08-27-2007 3:49 AM In reply to
    There is also tests to calibrate on every THX certified DVD. Most of the time if you click the THX logo in the sound setup.
    Cheers,
    Frank
  • 08-27-2007 5:51 AM In reply to
    • Tom
    • Luxembourg
    • Posts 3,175
    Thank you all, guys. I'll first try out the DVD kallasr will mail me and then I will see.
    But a big Yes -  thumbs up to all of you for your help!
  • 08-27-2007 8:16 AM In reply to
    • 355f
    • Top 100 Contributor
    • Posts 655
    tom:
    I think perhaps the reason you are neevr happy with the result is more to do with the LCD technology than anything else and how LCD makes the picture.
    If you increase brightness you lose the black( or grey levels) and the nature of lcd is that yellow and red are very vibrant. No amount of calibration will change the nature of the beast. Sounds like plasma would more suit your ideal
