Latest post 08-26-2007 2:18 PM by Beogen. 11 replies.
Page 1 of 1 (12 items)
  • 08-20-2007 3:13 PM
    • Beogen
    • Top 500 Contributor
    • Joined on 05-12-2007
    • Belgium
    • Posts 135
    BS3+RS232 confused
    Hej,
    According to the BS3 service manual the RS232 cable used to connect my Panasonic plasma to the BS3 should be crossed (2>3, 3>2, 5>5) but the cable that I'm using at the moment is one on one (straight) and seems to do the work. Do I misunderstand something, did I do a wrong measurement or is it a fault in de service manual (not likely)?
    I need to buy a longer cable or make it myself but I don't have a clue what it should be.
    What kind of cable or you using to make it work. Anyone using the original B&O cable?
    Thanks!
    Stefan
    Filed under:
  • 08-22-2007 7:44 AM In reply to
    • Beogen
    • Belgium
    • Posts 135
    Re: BS3+RS232 confused
    Anyone?
  • 08-22-2007 12:05 PM In reply to
    • frog
    • Joined on 04-19-2007
    • Posts 191
    Yes, the manual is correct - can't understand why your cable works!
  • 08-22-2007 2:57 PM In reply to
    • kawo
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 516
    I'm using the orginal B&O cable with my Panasonic TH-50PH10, unfortunately I needed a gender changer to make it work. Switch on and off works, but nothing else (like contrast or size adjustment) strange....
    Karsten
    _________________________________________________________________________
    BV4-50, Beosystem 3, Beolab 5, Beolab 3, BV3-32, BV1, BS9000, Beolab 4, Beolab 2000, Beo4 Cinema
  • 08-23-2007 8:08 AM In reply to
    • Beogen
    • Belgium
    • Posts 135
    Any idea how this original cable is connected internally?
    I had exactly the same problem during my installation, on/off worked but no autocontrast. I 'tricked' the system by telling it is a BV4-50 D9 while my screen is a Pana 42" D9 and now everyting is working as it should be. Strange!
    Today I have been told by our IT guys that it shouldn't matter if the cable is crossed or straight. In some cases there is a build in RX/TX switch which looks at the input what is received and what is transmitted. The electronics should know what to do with it.
    Thanks for the input!
  • 08-23-2007 9:46 AM In reply to
    • kawo
    • Posts 516
    I did the same, selected a BV4-50 G9, but did not work.....
     Karsten
  • 08-23-2007 11:59 AM In reply to
    • 355f
    • Top 100 Contributor
    • Posts 655
    kawo:
     Karsten
    I bought BS3 on its own to run with my panasonic and could neveer get to control anything other than on - off no matter hwat the configuration.
    So i gave up and bought bv4 panel. Has anyone been able to connect a panasonic screen and control auto contrast, colour, conrast ect via the beo 4
  • 08-23-2007 12:18 PM In reply to
    • Max
    • Not Ranked
    • Devon
    • Posts 64
    I initially had a straight serial cable connected between my BS3 and my Panasonic and it changed the settings dynamically (demonstrated by shining a torch on the sensor) but since the latest SW upgrade all it does is on/off. After having both scenarios, I prefer it not to control the screen as it always seemed to make the picture too dark. I'll probably end up with a BV4 at some point so I can live with it for now.
    Max.
    My B&O is in my Bio.
  • 08-24-2007 6:11 PM In reply to
    • Beogen
    • Belgium
    • Posts 135
    Sorry, but I forgot to mention the most important. I have changed the setting 'Monitor autodetect' in the customer service menu to 'No' in order to make the autocontrast work with the Panasonic. Shortly after this change I got the message 'Safe mode' on the screen but after resetting the BS3 this message dissapeared. Maybe you can try this to make it work.
    I also noticed that the screen became darker but at the moment I'm doing some tests with the BV9 autocontrast sensor which is more sensitive in my opinion. It looks better but now I have to build this sensor into the existing BV5 holder.
    BTW, I'm building my own BV5 HD or a 'baby' BV9. I ordered a lot of BV5 spare parts, bought a broken Avant using the motorstand and speakers/amplifiers, a Panasonic D9 and a BS3. Everything works but I still have to make my own +/-20V power supply and a delay circuit to make the center speaker work without the 'plop'.
    Still some work to do...
  • 08-25-2007 12:54 AM In reply to
    • cozza
    • New Zealand
    • Posts 119
    Beogen:
    This is sometimes true for ethernet devices, but is not the case for RS-232.
  • 08-25-2007 5:16 AM In reply to
    • kawo
    • Posts 516
    Interersting! I changed the Autodetect to "no" as well and least the contrast works now!
    thank you
    Karsten
  • 08-26-2007 2:18 PM In reply to
    • Beogen
    • Belgium
    • Posts 135
    Glad I could help you out!
