Latest post 08-23-2007 10:10 AM by V13WNG. 7 replies.
Page 1 of 1 (8 items)
  • 08-22-2007 8:01 PM
    Beovision 7-40 without centre speaker
    I have a pair of Beolab 3 and am thinking to purchase the Beovision 7-40 without the centre speaker (Beolab 7-2 or Beolab 7-4). So what are your recommendations ? Do I really need the centre speaker ? The Beolab 3 will mainly be used for TV, DVD and to play music through the Beovision 7-40.
  • 08-23-2007 7:00 AM In reply to
    • Tom
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Luxembourg
    • Posts 3,175
    Re: Beovision 7-40 without centre speaker
    You can sure buy a BV7 without centerspeaker, but I think that the sound of TV and DVD will be very strange. I would not recommand you to do that. If you have a budget and need/ want the TV right now, why not go for the 32" model WITH a center??
    Music washes away from the soul the dust of everyday life. - Berthold Auerbach
  • 08-23-2007 9:03 AM In reply to
    I think for TV it will be all right since it is broadcasted mostly in stereo to begin with. For DVD, speech may be a bit muddy and definilty not as clear as it would be with a center.
     What would bother me more is that most (all I know) mounting options are designed to have a center speaker below the TV so you might be staring at a clamp or the hole for the cable.
    Cheers
    JK
  • 08-23-2007 9:06 AM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    I'd recommend that you get the 32" with a beolab 7.4! How far away will you be sitting from the television?
  • 08-23-2007 9:44 AM In reply to
    • kawo
    • Top 150 Contributor
    • Posts 516
    I am not 100% sure but if recall it right the Beosystem 3 build in the new 7-40 does not allow to run without a center speaker. I think there is no "none" speaker available for the center.
    Please check this out before you are disappointed if you consider the new 7-40
    Karsten
    _________________________________________________________________________
    BV4-50, Beosystem 3, Beolab 5, Beolab 3, BV3-32, BV1, BS9000, Beolab 4, Beolab 2000, Beo4 Cinema
  • 08-23-2007 9:45 AM In reply to
    • mbee
    • Joined on 04-18-2007
    • Paris, France
    • Posts 1,133
    jk1002:
     The speach will definitely not be muddy with Bl3!! The definition of these speakers is incredible!! With 2 beolab 3, you will get a better sound that a lot of other 3.1 systems on the market. The real difference will be in sound positionning and clarity of voice at very high volume. I always listen to my (non-B&O) TV with only the beolab 3 in stereo, and watch movies with my beamer also in stereo, and all my friends agreed to say that my stereo was way better than their 5.1. Of course a beolab 7.4 will improve the sound, but not a lot with TV, which is broadcasted in stereo, just with DVDs.
    You can plug the sound output of a dvd player to the input of your stereo, and just listen what you get, that's really good. You can always buy a bl7.4 later.
    My thought are only correct if you can set the BV7 center channel to "none", or set it to speaker 2 option, this was possible with the BV7 MkI and II, I hope it's still possible with the new one "bs3 based".
  • 08-23-2007 9:50 AM In reply to
    I have read that Beo retailers would not be allowed to sell a BV7 without a speaker.
    Although I am sure they would.
    I'd still recommand you get the speakers, as you'd be able to enjoy a nice surround sound.
     p.
  • 08-23-2007 10:10 AM In reply to
    • V13WNG
    • Top 500 Contributor
    • Joined on 06-11-2007
    • Eastbourne, East Sussex, ENG
    • Posts 200
    If I remember rightly (it's been a while since I've crawled behind the back of a 7-40), there are two PowerLink outputs for the Centre speaker, as well as an extra centre speaker output on the Dolby Board.
    If you use a pair of BeoLab 3's, you'll need to plug them into the centre speaker outputs, as you will not get any sound at all without a centre speaker activated.
    Muchos Gracias Cool
