darioazul:
PS,
Any thoughts on the following future set with the BV 7(dark gray): BL 7-4 center (, BL 9 (dark gray) fronts, and BL 3 (red) rears.
I just saw the new BeoVision 7 in person-- all I can say is "Wow."
The speaker combination sounds optimal. If it were I, I wouldn't go with a dark color on the BV7/BL7. It will blend in too much with the black screen color and make your TV set look a bit more ~normal~ than it is. The aluminum frame behind the screen is really really special, and you want it to stand out! If you have red in your room (sounds like you do!) I would go with the RED option, or silver if you're less bold. Then you'll have a continuity in the textures of your design: all your aluminum surfaces (BL3s, BV7, BL7) will be red, and your cloth surfaces (BL9) will be dark gray.
Plus, you'd be one of the very few people in the Midwest (conservative land!) with an AV setup in any other color besides black or gray. (I took a look at your timezone, and I'm assuming you're in the Midwest somewhere.)
