        1st March February 2012
	    Latest post 02-27-2012 2:11 PM by Michael . 6 replies.
								    |  02-27-2012 11:01 AM |  |
									                 MichaelJoined on 12-31-2011Båstad, SwedenPosts 16 |
										    Hi guys!   I wonder if anyone here has made a masterlink -> rj45 cable here. I have the tool for making rj45-contacts and I have a few old masterlink cables that I would like to cut in halv and put a rj45-connector on. Is it that simple or what should I do?  I can buy new cables that alreade are masterlink-rj45 but they are about 50 dollars each and I need four or five, since I already have cables I cant just go out and buy cables for 250 dollars when I could probably make them of old junk for free :).     |  |
									                 kallasr
 Joined on 04-19-2007Willich, NRW, GermanyPosts 1,077 |
										    PLEASE use the search function.... (Masterlink RJ45 Ethernet etc.) AND visit http://beotech.beoworld.org/ Ralf My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1. |  |
										    Thank you Ralf, I have been reading a bit and I also have the "Cat7/Class F New Installation
Concept New infrastructure Handbook" from B&O. I just wanted to know if anyone had done this themselves out of old cables.
 It seems a bit hard so I´ll probably end up buying the cables instead. Another thing, people are sayint that it only works on Cat7, I would say this is not true. I live in a house with a lexcom-system and it supports Beolink. I checked the cables for about an hour ago and it is the same cables that are used in beonet officiall cat7 solution as in lexcom that is only cat6.
									                 kallasr
										    I did it myself using old cables - it can be done, so give it a try. Even with mcl2 cabling (old for the beomasters and beocenters). Now I use the lexcom cables, just looks much nicer and no possible source for errors... Best regards RalfMy Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1. |  |
										    Aha! Good to know! Which colour do you have on your lexcom-cables? Hard to hide the connector itself.   Did you use shielded RJ45-connectors? I think that is necessary but I don't have the type specified in B&Os guide, but I do have a few shielded standard connectors. And many more unshielded.    |  |
									                 kallasr
										    I just took some patch-cables and cut them in half, attached one end to half a masterlink cable with connector. Did't sort of look like this (MCL Cabling but quite the same for Masterlink - just be aware, one wire is not used):
   Good luck! Ralf My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1. |  |
										    Thank you for the pictures! Interesting to see that you did not need to use the shield as ground or anything. I will try this myself but I'll probably try to put the RJ45 connector directly on the ML-cable but we'll see :) Thanks again!   |  |
						     Page 1 of 1 (7 items)  |
