With the Beocenter 9500.....i was wanting to mount it on a wall where it was not facing my bed in the bedroom. In fact the face of the BC9500 would be facing 90 degrees (perpendicular) from the bed....
Will it still work OK from there???
Thanks.k
Never known a B&O remote which needs to be pointed. Due to the frequency used as long as you are in the same room I cannot see a problem. If you look at the front of your BC9500 you will see the I.R. reciever. It is a squarish part that sticks out.
Craig
If you use a Beo4 you can fire it in the opposite direction if you wish and it will still work!
The Beolink 1000 is not quite as efficient.
Regards Graham
I've found the BeoLink 1000 to still be very good when it comes to directionality. I can use it from anywhere in my room pointing in any direction, and it always works.
Weekly top artists:
Alex: I've found the BeoLink 1000 to still be very good when it comes to directionality. I can use it from anywhere in my room pointing in any direction, and it always works.
It depends how big your room is Alex. When you get older you will realise that size IS important!
