Latest post 08-09-2007 12:08 PM by The Stig - ver. 1.7. 3 replies.
Page 1 of 1 (4 items)
  • 08-09-2007 9:43 AM
    MX1500 in link setup?
    Can a MX1500 be used in a materlink system? Also is there a wall bracket available for this set?
    Never Mind The Ball-Cocks www.markmossplumbing.co.uk
    A labourer uses his hands
    A tradesman uses his hands and his head
    A craftsman uses his hands, his head and his heart
  • 08-09-2007 10:00 AM In reply to
    • ChrDH
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Denmark
    • Posts 493
    Re: MX1500 in link setup?
    I think there were a wall bracket, I have seen some used for sale here in Denmark, I do not know if they are original or some other maker than B&O.
    With respect to the link solution, it is in no way possible. The MX1500 have neither datalink, nor masterlink. One possibility is to use the scart connection in some way (take the sound in via a scart to RCA cable), but I do not think this will work.
     br
    Chr.
    Beosound Ouverture, Beocenter 9000, Beovision MX6000, Beocord VX7000
  • 08-09-2007 11:09 AM In reply to
    It is actually possible but not sensible! You will need to get a way of having an IR eye to control the link system and tune the MX1500 to the link frequencies. We do have members who have done this but it is complicated and as you can get an MX TV of newer vintage that will just work for next to nothing, the sensible answer is exactly as Christian has stated!
  • 08-09-2007 12:08 PM In reply to
    Yes like peter says you will need a beolink active placed next to the MX1500 and a Master TV where you can set modulator to always on. then it's no problem
