hello folks - hope i'm not digging up an old topic - i did a search first but couldnt come up with the correct answers.
I have an MCL 2A unit and a Beocenter 8500, currently i'm running Redline RL45.2's from the speaker 1 socket.
the MCL 2A kit i bought only comes with the cable between the IR reciever and the wall box but not for the stretch between it and the beocenter!
I just need to know where i can get the 4 pin din connectors so i can connect up some 4 core cable between the beocenter and the MCL unit! i've looked everywhere online but can't find anywhere which will sell the correct 4 pin din connectors that i need - or do i need to use genuine B&O MCL cable? if so where can i get some from? do the dealers still stock it and is it very pricey?
also, will it affect the sound quality of my redlines - i'm planning on using CX50's in the link room and next year hope to replace the redlines with Beolab 8000's (have a bit of saving to do until then!)
