Latest post 08-07-2007 8:47 AM by Peter. 2 replies.
Page 1 of 1 (3 items)
  • 08-07-2007 7:59 AM
    • alda13
    • Not Ranked
    • Joined on 08-06-2007
    • Posts 2
    Beocenter 2600+Beovox CX100?
    Hello!  I just wonder if it´s possible to combine a Beocenter 2600 with my four speakers namned Beovox CX100. The impedance of the speakers is 6ohm and the Beocenter say 4ohm speakers to be used. Anybody who knows?
    Best regards from Mats
  • 08-07-2007 8:42 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beocenter 2600+Beovox CX100?
    That would be fine.
  • 08-07-2007 8:47 AM In reply to
    No problems at all. Speaker impedance is just a rough value as it varies massively with frequency anyway. The problem will usually be with too low impedance anyway. Higher impedance speakers are an easier load to drive as far as the amplifier is concerned though as the impedance increases, the efficiency goes down. If you have a perfect amplifier and very low impedance speakers, you should get more power. In the real world, as the impedance decreases, there is an initial increase in power output but this rolls off and decreases at about 3-4 ohms for most amplifiers. CX100s will be fine! My LS3/5As are described as 11 ohms and the earlier ones as 15 ohms. Almost any amplifier can drive them!
