Latest post 08-03-2007 3:41 PM by Keith Saunders. 15 replies.
Page 1 of 1 (16 items)
  • 06-18-2007 5:36 AM
    • deaddruid
    • Top 500 Contributor
    • Joined on 05-24-2007
    • Malvern, Worcestershire
    • Posts 247
    Beocom 6000 - identification
    I gather from the "products" part of the website that the Beocom 6000 was made in two versions, and that the newest phones can't be used with the old base stations. How do you tell, from looking at the phone or the base station, whether you have a new or an old version? I assume that on the new phone, there will be a 3.5mm jack socket, but what change was made to stop these phones fitting the old base-stations?
    Mark
  • 06-18-2007 10:20 AM In reply to
    Re: Beocom 6000 - identification
    The shape of the contacts on the charger was changed.
    Regards Graham
  • 06-18-2007 11:39 AM In reply to
    The old ones have two black plastic plugs on top. The new ones have a socket for the Earset 1 - not a jack plug. Essentially, if there is a hole in the top with some contacts on either side it is a new one. The new ones work with the old Beoline but the old ones don't work with the new Beoline. The phone will come with its own charger so this is less of an issue except you cannot move phones around from charger to charger if they are different types.
  • 06-18-2007 12:09 PM In reply to
    Mark,
    Appending to Peter's comments, the buttons on a Mark I are below
    Mark I
    AND a Mark II looks as below
    Mark II
    Regards Keith....
  • 06-18-2007 2:51 PM In reply to
    • deaddruid
    • Posts 247
    Thank you, guys, that's really helpful, and I now understand how to differentiate the handsets. Now, one more question... How can I tell whether a base is for a mk1 or a mk2 handset? As an aside... given that there seem to be so many variants of B&O kit, would it be worth collecting details such as these into an "identification" section of the website? Mark
  • 06-18-2007 3:08 PM In reply to
    Very easy, If you look at the two brass pins in the charger base, if they round, they are for a Mark I handset, if they are elongated, then they are for a Mark II.
    In fact if you try and place a Mark II handset on a Mark I charger it will not make contact, just as well as they are different voltages.
    Regards Keith....
  • 06-18-2007 3:14 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Peter, I have had many of the MK1s apart but have never even seen a MK2. The black plastic plugs on top hide the IR sender for AV volume. Do you know whether the MK2 have the IR in the same place? Doesn't seem possible if there is a headset plug there instead.Confused
    Andy T.
    Poor me, never win owt!
  • 06-18-2007 3:26 PM In reply to
    The IR is next to the socket in the Mark II as below
    IR
    Regards Keith....
  • 06-18-2007 3:32 PM In reply to
    • Jandyt
    • Posts 13,004
    Thanks KeithBig Smile
    I will be able to sleep tonight, now.
    Andy T.
  • 06-19-2007 2:18 AM In reply to
    Andy,
    I trust you had a full nights sleep and are fully awake, let me see it is now 7:20am and I have been at work (that's money earning work) since 6:15am, time for my coffee break.
    Regards Keith....
  • 06-19-2007 4:32 AM In reply to
    deaddruid:
    There is a section of FAQ's already and in there is a section on compatability of BeoCom 6000 & BeoCom 2 phones with the various PSTN bases.
  • 06-19-2007 4:36 AM In reply to
    • deaddruid
    • Posts 247
    Thank you for your help.
    It's not easy working out how to identify the variants, and those of who can only afford to buy second-hand need to be able to tell the difference!
    Mark
  • 06-19-2007 4:45 AM In reply to
    • deaddruid
    • Posts 247
    meandmyshadow:
    Not when I look at it! It tells me "no results found" for each of BeoCom  6000 and BeoCom 2.
    Mark
  • 06-19-2007 7:41 AM In reply to
    deaddruid:
    meandmyshadow:
    Mark
    Try this link: http://www.beoworld.org/faq_view.asp?id=74
    You will find it, from the main page, FAQs - General FAQs - BeoCom Telephones.
    I hope you find it useful.
  • 08-02-2007 10:26 PM In reply to
    • Goldfrog88
    • Joined on 06-07-2007
    • Melbourne, Australia
    • Posts 83
    • Gold Member
    Keith, are the voltages so different? I saw the three cells of the phone battery that normally indicates 3.6V, and so enlarged the holes on the old charger to fit the new phone (after disassembling the charger unit and removing the pin that might be just some kind of spring mechanism?). It has been charging well for the last month now. I'm talking of the wall charger here, the dark brown/grey one with a U-shaped holding tongue.
    Kind regards, Mike
  • 08-03-2007 3:41 PM In reply to
    Mike,
    You raise an interesting comment about the different pins for Mark I & Mark II chargers. In my view this was part of B&O's normal practice of thinking ahead particularly related to advances in battery technology, but was never really implemented. However, in practice and certainly in the UK Mark I and II chargers produce an unloaded charging voltage of 5.6 volts and the phones have the standard 3.6 volts cells made up of three 1.2 volt cells.
    My comments relate to the first generation wall chargers you have described. You could do as you say and increase the size of the holes. You could also purchase a new front cover for about £15
    Regards Keith....
