does anybody have a XML file for this box?
Or can help me translate it ?
It's an RC6 code and I don't know how to convert it, so I can make a XML file of it.
Many thanks and kindly regards,
Marius
The RC6 Code is :
[REMOTE]
[NAME]Humax_HD-PR_5000
[TIMING]
[0][ N]0[RC]2[FL]105[FREQ]36[RC6][SB][RS]
[COMMANDS]
[TV][T]0[ D ]S11101010000000010010000010011010100110
[SKY][T]0[ D]S11101010000000010010000010011010000011
[Power][T]0[ D]S11101010000000010010000010011000001100
[1][T]0[ D]S11101010000000010010000010011000000001
[2][T]0[ D]S11101010000000010010000010011000000010
[3][T]0[ D]S11101010000000010010000010011000000011
[4][T]0[ D]S11101010000000010010000010011000000100
[5][T]0[ D]S11101010000000010010000010011000000101
[ 6][T]0[ D]S11101010000000010010000010011000000110
[7][T]0[ D]S11101010000000010010000010011000000111
[8][T]0[ D]S11101010000000010010000010011000001000
[9][T]0[ D]S11101010000000010010000010011000001001
[0][T]0[ D]S11101010000000010010000010011000000000
[Suche][T]0[ D]S11101010000000010010000010011001000000
[<][T]0[ D]S11101010000000010010000010011000111010
[Guide][T] 0[ D]S11101010000000010010000010011011001100
[Menue][T]0[ D]S11101010000000010010000010011001010100
[Select][T]0[ D]S11101010000000010010000010011011110000
[Info][T]0[ D]S11101010000000010010000010011000001111
[Up][T]0[ D]S11101010000000010010000010011001011000
[Down][T]0[ D]S11101010000000010010000010011001011001
[Left][T]0[ D]S11101010000000010010000010011001011010
[Right][T]0[ D]S11101010000000010010000010011001011011
[OK][T]0[ D]S11101010000000010010000010011001011100
[Vol Up][T]0[ D]S11101010000000010010000010011000010000
[Vol Down][T]0[ D]S11101010000000010010000010011000010001
[Zurueck][T]0[ D]S11101010000000010010000010011001010101
[Mute][T]0[ D]S11101010000000010010000010011000001101
[Prg Up][T]0[ D]S11101010000000010010000010011000011110
[Prg Down][T]0[ D]S11101010000000010010000010011000011111
[Rec][T]0[ D]S11101010000000010010000010011000110111
[Archiv][T]0[ D]S11101010000000010010000010011011010101
[Stop][T]0[ D]S11101010000000010010000010011000110001
[Backward][T]0[ D]S11101010000000010010000010011000100001
[Play/Pause][T]0[ D]S11101010000000010010000010011000111000
[Forward][T]0[ D]S11101010000000010010000010011000100000
[iTV][T]0[ D]S11101010000000010010000010011001000110
[Zoom][T]0[ D]S11101010000000010010000010011011011000
[Hilfe][T]0[ D]S11101010000000010010000010011010000001
[Text][T]0[ D]S11101010000000010010000010011000111100
[Red][T]0[ D]S11101010000000010010000010011001101101
[Green][T]0[ D]S11101010000000010010000010011001101110
[Yellow][T]0[ D]S11101010000000010010000010011001101111
[Blue][T]0[ D]S11101010000000010010000010011001110000
