hello,
i recently took delivery of a bv7-40 :)
unfortunately, this means i can no longer distribute n.music from my mac mini with bm-link. the bv7 is a videomaster only. my former videomaster/audiomaster is a bc1 and it can not be declared as an audiomaster only. so i turned to linkplayer (v1.1) which can play the role of audiomaster.
and i can not get it to work.
i have declared linkplayer as option 0 (no audiomaster, beoport in same room as videomaster). linkplayer loads on my mac mini without error. it reacts to the l-n.music command from my beo4 via the bv7.
strangely enough it reacts by opening system preferences, then the sound preference pane. linkplayer then switches from standby to n.music and starts playing track 1 from my itunes library.
however, the bv7 does not turn on (little indicator light stays red) and no music comes through speakers.
am i missing something, has anyone seen this behavior before ? any and all help appreciated,
- scott
