sadly no, the Wireless is meant for remote connection of link room speakers, not additional sources.
does it make sense to consider something like the new CAT7 approach ... that cable maybe thiner and more flexible than the ML.
I was think of suggesting using the CAT7 to connect the two systems via "ethernet over power" but I have no idea if that would actually work !
but maybe some other ethernet to ethernet wireless technology would do the job ?
does any one else know ? or tried this approach ?
									    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
