I am total newbie in Beosound world and and I am facing problems with my system - BeoSound 9000 connected with Powerlink to  MCL2P which drives my passive speakers.
When I received the unit it went (or was set) to Option 0 (tv operated)). I found the setting instructions how to change this as stand alone system (a.opt 1) with a borrowed Beo4 rcu. Everything was fine for few days and now it has returned to this same state so I cannot control e.g. volume any more (pressing buttons will show TV OPERATED info msg). So 2 questions (now 3):
1. Is there any way to change the option without Beo 4 (or other Beo) rcu ?
2. How I can get it to keep the setting, it is way too difficult to teach for rest of the family ?
3. Is there any difference which Powerlink output I use for connecting MCL2P ?
I am going to buy Beo 4 but seller is out of town for weekend and I have new years party tomorrow, so your quick help is preciated.
++tapsa
PS. I do own few programmable remote controllers (Sony RM-AV2500 and One4All 8) if those could help ? I quess i would need to find right codes for them. For Sony I am using B&O codes space, but it lacks the red dot, LIST and GO buttons, so no help there
