pepps:I'm having a similar problem with a pair of stunning 3702s. Grinding from the coil. Worse though is the spider on mine is sort of ruffled and not flat like yours.
If you receive any tips do PM me :)
Thanks!
Check the pics of my 3702  here which type are your 3702s 6244 or 6263, if 6263 could you check the crossover and tell me, which size are the resistors and the capacitors, or/and post a pic.
									    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
