Latest post 12-27-2011 11:37 AM by tournedos. 3 replies.
Page 1 of 1 (4 items)
  • 12-27-2011 3:35 AM
    Beolab 6000 Spares
    Could anyone point me in the direction of where I could get hold of a pair of beolab 6000 frets and replacement tweeter. I've been trawling ebay for ages with no luck.
    regards
  • 12-27-2011 6:56 AM In reply to
    Re: Beolab 6000 Spares
    There's some 6000 frets on ebay now with just over 24hrs to go, here........
    http://www.ebay.co.uk/itm/Bang-Olufsen-Bio-Lab-6000-Frets-/120832980293?pt=UK_AudioVideoElectronics_HomeAudioHiFi_HiFiSpeakers&hash=item1c2234f545
    As for the tweeter I'm not really sure, except suggesting going directly to B&O and seeing how much the part is new.
    Regards,
    Michael
    BV5, BV Avant, MX4000, MX1500
    BS 7000, BS 5500
    Penta III, Penta II, BL 4000, RL 60.2,  RL 35, CX-100 Alu
    BL 7000, MCP6500, MCP5500,  BL 5000,  Beo4 (x2), BL 1000 (x2)
  • 12-27-2011 10:27 AM In reply to
    The tweeter doesn't cost that much is it?
    What happened with the frets you have now? If it's just the cloths they are easy to be reclothed you know! Just did a pair for a friend of mine.
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 12-27-2011 11:37 AM In reply to
    The tweeter is the same as in Beolab 8000 (and a number of other products, including some televisions!) and will probably cost you ~50 euros at the dealer. Don't bother trying to find a generic replacement.
    Swapping the tweeter itself is no big deal, but you will also receive a bagful of SMD components you might need to replace at the amp, depending on how old your speakers are... these update the treble protection circuit so that the new tweeter won't blow quite as easily.
    The treble level should also be calibrated, but you might opt to leave that alone since nobody will ever know you didn't.
    -mika
