Latest post 04-21-2007 12:35 PM by Craig. 2 replies.
Page 1 of 1 (3 items)
  • 04-21-2007 2:00 AM
    • oden
    • Not Ranked
    • Joined on 04-16-2007
    • Germany
    • Posts 27
    PC2 vision signal to MX
    Hello,
    How I get the picture PC2 (the black information window from the PC2 software ) on a MX?
    Does the signal go about the ML cable or the aerials kabel?
    What must I adjust at the MX?
    Thank you for the help.
    Greeting Thomas
  • 04-21-2007 2:41 AM In reply to
    Re: PC2 vision signal to MX
    Thomas,
    I am not sure I fully understand your question.
    You have your PC2/Beoport connected and working on your PC. Do you mean you want the black windows you have on your PC screen on your MX ?
    On the ML (Masterlink) there is ONLY audio and control signals, no video goes via ML in any setup
    Keith..
    Regards Keith....
  • 04-21-2007 12:35 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    oden:
    Hello,
    Greeting Thomas
    You may be able to do this if you have a Graphics Card with a TV out feed. Not sure though if it will show what you want. When I had Beoplayer running on a spare PC I was never able to get Beoplayer displayed on the TV. Although I could get Windows Media Player on the TV.
    CraigBig Smile
