Latest post 12-05-2011 4:53 PM by mediabobny. 7 replies.
Page 1 of 1 (8 items)
  • 05-13-2010 1:48 PM
    • Dirk7r
    • Not Ranked
    • Joined on 05-13-2010
    • Posts 5
    beocentre 2200 tape problem
    hello i have a very nice beocentre2200 but i am having trouble with tape player ,iy you press any of the tape buttons its sounds like if it is working but nothing is happening,can anyone please help with this problem,
    best regards
    Dirk
  • 05-13-2010 2:23 PM In reply to
    Re: beocentre 2200 tape problem
    Welcome to BeoWorld!
    On the surface -sounds like belts... pretty typical.
    Member: Dillen has belt kits available... you can try PM'ing him -or he'll likely be along before too long.
    • B&o bottle opener
  • 05-13-2010 3:40 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Agree with Jeff, most likely the belts. Fairly easy to change yourself too.
    CraigSmile
  • 05-13-2010 5:42 PM In reply to
    • Dirk7r
    • Not Ranked
    • Posts 5
    thanks guys for the info ,i will get the belts changed
    many thanks dirk
  • 05-17-2010 5:53 PM In reply to
    • Dillen
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    I agree.
    Belts for the Beocenter 2200 cassette section are available as a set with all three.
    PM me for details.
  • 05-18-2010 12:27 PM In reply to
    • Dirk7r
    • Not Ranked
    • Posts 5
    Hi martin ,
    can you supply me the belts,or where to get them  no problem to paypal .
    Regards dirk
  • 12-05-2011 4:33 PM In reply to
    Hi
    I have a Beocentre 2200 and the tape drive has just stopped working with the sysmptons similar to those described in this thread - press play and the tape deck wirrs for 5 seconds before switching off. Same with fast forward and reverse. The heads do not move when play is pressed.
    Where can I get spare belts from? How do I verify it is the belts?
    Mark
  • 12-05-2011 4:53 PM In reply to
    • mediabobny
    • Top 200 Contributor
    • Joined on 04-19-2007
    • Greenwich Village, NYC
    • Posts 336
    Per the earlier part of this thread, member 'Dillen' can provide them.  Send him a PM.
