Latest post 11-22-2011 7:51 AM by vegar. 8 replies.
Page 1 of 1 (9 items)
  • 10-29-2011 1:58 PM
    • vegar
    • Not Ranked
    • Joined on 10-29-2011
    • Posts 6
    Beocenter 2300/2500 upgrade
    Hello to all, after getting alot of help reading the forum anonymeous, I just joined this site to be able to post.
    The other day I found this link http://w1.1983.telia.com/~u198300398/bc.htm and am wondering if anyone have done this modification? I cant seem to find anything on this forum about changing the opamp and removing alot of caps on this unit so cureous about it.
    Filed under:
  • 10-29-2011 3:38 PM In reply to
    Re: Beocenter 2300/2500 upgrade
    Yes, me, i made these modifications. It works and the sound is perfect.
    There are several audiophile workshops around this topic... just look for "workshop" in the workbench section  Whistle
  • 10-29-2011 4:25 PM In reply to
    • vegar
    • Not Ranked
    • Posts 6
    Ah, nice thanks for quick reply:-) I am having a 2500 unit on the way to me in the mail with two beolab 6000, if I dont like the sound in it I am gonna try this modification/upgrade, this upgrade seem abit strange tho concerning removing the caps for copper wire, do you know why this improves it?
  • 10-30-2011 4:51 AM In reply to
    No cap is better than one cap or a lot of caps Wink
    Caps are magnetic, they are resistors/coils and caps in one, changing the signal.
    But the caps have a function, just transmitting a signal but no during current.
    It is possible to remove them if there is no DC offset. And this means to measure the dc voltage of every cap. If there are 0,0xV, then it is possible to remove the cap.
    But you must know the circuit and what every piece is used for. Just cutting out parts will destroy the unit.
  • 10-30-2011 5:25 AM In reply to
    • vegar
    • Not Ranked
    • Posts 6
    Thanks for clearing that out:-)
    Before I go ahead and order OPA2134UA is this the one you recommend or are there other opamps to consider that are even bether?
  • 10-30-2011 7:42 AM In reply to
    The OPA series ist the best price for this perfekt quality. There are a little bit better ones available, at 10x the cost and not 100% compatible.
    The OPA 2134UA is probably the best one you can get. They can replace the LM833 or MC4558 and there is an effect you can hear.
  • 11-08-2011 11:46 AM In reply to
    • vegar
    • Not Ranked
    • Posts 6
    I have gotten the units now and did a listening I find the onboard cd and casette deck quite good sounding, but the other day I tried the Aux with some digital sound omg. that sounded as it needed some sorting. will this modification help on the aux source aswell or?
  • 11-22-2011 2:12 AM In reply to
    • vegar
    • Not Ranked
    • Posts 6
    Hi there.
    I have located all the caps to be taken out now on my pcb 2 board, the opamp however seem abit harder to locate as they are not marked. Howevere I got 6 opamplike ic's on the back on the pcb from where all the caps sit. They are named: 353 st9401 and 4-558c st9405, are those the ones I shold change?
  • 11-22-2011 7:51 AM In reply to
    • vegar
    • Not Ranked
    • Posts 6
    I changed all the caps for copper wire now, used some left over wire. I halfway assembled it again and tested...ofc. I only got left channel sound resoldered everything and tested with a cd with Erykah Badu and it all worked I can hear a huge difrence on the base its way more precise on my beolab 6000. Considering I have not yet changed the opamp this is a rather unexpencive upgrade, with benefits:-)
