Hello
I have upgraded my Virgin Media box to a Tivo box.
Since this upgrade when I turn the televison on the Tivo box does not come on screen automatically. The only way to get it to work is by pulling out the scart then back in again. Nothing else is connected to the tv at the moment.
The difference between the boxes is that the old Virgin media had an ariel input Tivo does not.
I have looked at the menu options on the tv. Is there a specific setting required in the connection menu?
Thanks in advance.
