Hi all
as elsewhere got a cx base driver with a coil(?) problem, after all the posts over time, as anyone got a single driver available - ie the one with the hole in the rear face if so via the forum or by pm
tony
I always try to operate using/following the KISS principle -- Keep it simple stupid!
Try this for a matching item,
http://www.ebay.co.uk/itm/Bang-Olufsen-Beovox-C40-Main-Driver-Woofer-Used-B-O-/130580542852?pt=UK_AudioVideoElectronics_HomeAudioHiFi_HiFiSpeakers&hash=item1e6734f584
Missed the end, mailed the seller!
However, anyone else got one?
Furgot to add, just needs to be working, foam rot is not a problem!
Bump!.......... Anyone
you have mail
Thanks Nick!!
No longer lo0oking!
Tony
