Hi there,
Anybody knows where would be a best place to find Beovox S45 stands?
Janez_Novak: Hi there, Anybody knows where would be a best place to find Beovox S45 stands? Thanks
Attached to S45's???
Sorry, sorry, didn't mean to be flippant! I think the best suggestion would be keeping a close eye on ebay to be honest. You could do a search of finished auctions and get an idea how often they surface - I suspect the speaker/stand combination crops up more often than the stands alone.
Welcome to Beoworld !
Note that there are three different Beovox S45 types (6302, 6312 and 6427).Which type do you have ?
Hi Puncher, Dillen. Thanks for your reply. I am watching ebay, but just wondered if there is another place as well.
I am not sure which type it is yet since the speakers are being posted to me right now, but they are the earlier three-way 70s model.
Here
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
As far as I remember, there were no dedicated stands for the earliest version (6302). It hadholes (actually cast brackets) at the back for hanging on the wall but no threaded holes for the floorstand.The newer Beovox S45.2 (6312) had the holes at the back.The two types are easy to tell apart, even from a distance, in that the S45.2 has an alu framearound the rear as well the front.
I just sold a pair of stands for the type 6312 on Ebay last week and I have one more pair.
Hi Martin,
Thanks for clarifying this for me. I know for sure they are not the S45.2, I was a bit impatient so I just bought S45 model which i found on ebay. I would say I am interested in stands but looks like I might have to keep the speakers on teh floor.
Cheers
thanks for link Soren.
Dillen: As far as I remember, there were no dedicated stands for the earliest version (6302). It hadholes (actually cast brackets) at the back for hanging on the wall but no threaded holes for the floorstand.The newer Beovox S45.2 (6312) had the holes at the back.The two types are easy to tell apart, even from a distance, in that the S45.2 has an alu framearound the rear as well the front. I just sold a pair of stands for the type 6312 on Ebay last week and I have one more pair. Martin
Any other secrets you're keeping from us?
Like M70 trumpet stands?
Current primary listening: SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
Rich: Any other secrets you're keeping from us? Like M70 trumpet stands?
I have no secrets, just a lot of things.Too much if you ask people around me. But not a lot of trumpets, I'm afraid.
Hallo Martin,
this time I am to find a pair of original speaker standsfor my Beovox S75 pair - the square stands, not the trumpet ones. Do you probably, by any chance have a pairfor sale? it seems to be very hardto find one :( maybe you can help?
best regards,
Wolfram Luchner
