Latest post 10-13-2011 12:43 PM by Keith Saunders. 5 replies.
Page 1 of 1 (6 items)
  • 10-11-2011 12:42 PM
    • kimhav
    • Top 500 Contributor
    • Joined on 09-03-2007
    • Sweden
    • Posts 127
    IR receiver cable pin question
    I need to make a IR receiver cable for a BeoLink Passive unit; but can't find any information regarding the pin layout for the DIN7. Any one able to point in the right direction?
    Filed under: ,
  • 10-11-2011 2:41 PM In reply to
    Re: IR receiver cable pin question
    You may find the following helpful
    Regards Keith....
  • 10-11-2011 2:59 PM In reply to
  • 10-11-2011 5:23 PM In reply to
    Raeuber:
    Exactly what I was looking for, thanks Räuber!
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 10-12-2011 3:37 AM In reply to
    • kimhav
    • Sweden
    • Posts 127
    Hi Keith & Räuber ,
    Thanks for both replies; as I'm having an IR kit from B&O I assume that Räuber's suggestion is the way to go.
    Keith what you're suggesting with the schematics;  to be used together with the B&O IR kit?
  • 10-13-2011 12:43 PM In reply to
    My image is from the circuit diagram which shows the pin connections which is the same connections as shown in Räuber's image.
    The wiring to the Control is shown in the user manual
    Regards Keith....
