Hi All,
 I am new to the forum.  I acquired a set of beolab pentas and had them refurbished.  I cannot figure out how to connect them to a non B&O reciever, (Sony).  these are obviously active speakers.  The d-link input, line in input, are at the bottom of the speaker.
questions.
1) can these be hooked up to a a/v receiver which has amplified outputs (black/red terminal posts for each speaker (+)/(-) ) and if so, what type of cable/settings do i use? anyone know where to get these?  I imagine B&O's proprietary connector won't work, so how do i hook up the line in (RCA input jack) on the speaker, to the non-RCA posts (positive and negative posts for each left and right speaker) on the receiver?
2) if these active speakers require that I plug them into a preamplifier output (i.e,, not a 'amplifier' signal), and i don't have these outputs on my receiver, then what are options?
3) can these be used as passive speakers?  perhaps just by not plugging them in?
thanks in advance for any help.
they are just such beautiful speakers, i would hate to not be able to use them!
SK
