Latest post 09-21-2011 6:16 AM by elephant. 1 replies.
Page 1 of 1 (2 items)
  • 09-20-2011 6:21 PM
    • hatc11
    • Not Ranked
    • Joined on 09-20-2011
    • Posts 1
    Really nead help !
    Hi, Hope one of you might help me on this one.
    In my house there is an old MCL system and a Beomaster 5000 and 4 BeoVox CX100.
    The system can be controlled from the Beomaster 5000 or from the wallmounted control in the kitchen.
    Now I would like to upgrade the Beomaster 5000 to a Beosound 2300 or even better a Beosound 5.
    My question is if I can use the old MCL system with the upgraded Beomaster or I ned a converter.
    Please write if you need more info.
  • 09-21-2011 6:16 AM In reply to
    Re: Really nead help !
    To drive the CX100s from a MasterLink system you will need some (two by the sounds of it) of these I think:
    http://www.beoworld.org/prod_details.asp?pid=981
    And of course some MasterLink cables and probably a junction box to split the cables.
    It could be that this might be the right thing for you ... others can better advise you ... and possibly it could reduce the amount of re-cabling !
    http://www.beoworld.org/prod_details.asp?pid=984
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
