Hi Everyone,
I have a somewhat strange problem with my BM8000. A few months ago I exchanged all capacitors and trimmers in the output stages after I fried the TIPs in the right channel trying to adjust the no-load current with the original corroded trimmer (after I bought it it ran pretty hot on that channel). After the repair and replacement of the TIPs everything worked great. The temperature of the heat sinks was about 37C under normal operation.
A few weeks after the repair, the temperature of the right channel began to increase (~50C). I opened the BM and checked the voltage across R237/236 and found about 100mV (instead of the prescribed 18 mV for minimum no-load current). I adjusted the trimmer slightly and got it back down to 18 mV. Everything fine again...low temperature etc...
A few weeks later, same scenario...about 100mV, and a hot heat sink. I adjusted again to 18mV and checked the DC voltages around the TIPs...all seem normal. The supply voltages are also normal...
Something seems to go south, but I do not see what it might be! Or can it be that the trimmer "self-adjusts" due to temperature fluctuations?
Advice would be greatly appreciated!
Rudy
