1st March February 2012
Latest post 08-20-2011 1:03 PM by sergi0. 3 replies.
08-19-2011 6:04 PM
Hungedu
- Joined on 08-08-2009
- Ambergris Caye, Belize
- Posts 128
Just received my BeoVsion 7-55 3D TV!
I am in the process of setting up the TV. Does anyone out there know how to remove the little metal feet that are attached to the bottom of the TV panel when it is unpacked from the box? The metal feet are great because it allows the panel to sit striaght up without having to lean it against a wall before putting it on its stand. The problem is, the instructions don't show how to remove them. :-(
BeoVision 7-55 3D, BeoSound 9000, BeoSound 8, BeoLab 7-6, BeoLab Penta III, BeoLab 8000, BeoLab 6000, BeoLab 2, LC-1, BeoTime (analog clock), Form 1 headphones, Beo 4 remote.
Vienna
- Joined on 08-15-2008
- make an educated guess
- Posts 712
Re: Just received my BeoVsion 7-55 3D TV!
The t-shaped "Service-Stands" can be removed by pulling them "out/downwards" with a "little force" and "wobbling"
Prepare some towels/rugs to put them between floor and lower edge of TV otherwise, after removal of the feet, the whole weigt of your tv might be resting on the tray of your BluRay Player.
Hungedu
- Posts 128
Thank you, sir! Those instructions were all I needed. Worked perfectly.
sergi0
- Joined on 03-06-2011
- Posts 99
I am curious and interested by your Beovision 7-55 3D. Does it have a network plug somewhere on the back? I was wondering if this product will be Beonet'ed in the future.
cheers,
sergio
Page 1 of 1 (4 items)
