The original styrofoam and cardboard boxes are still available; have your dealer order them for you. When you're setting them up, be sure to glue to the middle supports, which wrap around the display portion of the speaker, into place against the sides of the box. Otherwise, the middle supports will migrate during transit. They need to be glued in place because the display area is the weakest point, structurally, of the speaker. There's only about 50% of the pentagon present inside to provide structural integrity.
