Thanks again. What you describe is what I see. However, another thing that makes me think something is missing is the feet. On the left side facing the turntable there are two feet?, one front and one rear. They are hard plastic angular corner pieces which seem to be part of the chassis mold. But they are missing on the right side altogether so the table sits tilted a bit. And the other thing is that the platter rides too low in the chassis and the record scrapes around the edge unless I stuff something underneath which elevates it. Like a small towel or a sheet of bubble wrap. I should figure out how to post some pictures here.
