Hi everyone,
I have a question about the VGA input on the BeoVision 8-40. I'm thinking about buying a new MacMini to replace my older one as the mediacenter in my setup. And then I got to thinking, that 'maybe' I can use the old Mini as a mediacenter for masterlinked televisions!?
Here is my question: Will I be able to distribute video to my other masterlinked tv's if I use the VGA input on the BeoVision 8-40?? VGA is analog, isn't it??
Regards
Claus
I was the second place winner on the BeoWorld May 2009 Prize Draw!
Thanks to BeoWorld for a great site!
